Digiwave Diamond and Satellite capacity of 64 entries | SatelliteGuys.US
regisma
58
Hi,
Can you confirm to me if the limit of the Digiwave Diamond is to support no more than 64 satellites?
thanks
Regis
Hi,
I have two LNB some satellites have a spectrum quite wide for FTA like the IntelSat 10-02 at 1.0W.
Someone explained me a trick so I can cover all the spectrum of it with two LNB.
The trick consist of create one satellite entry that handle the lower frequency and another one that is a clone of the first one but this second one will cover the higher frequencies. So if there is a limit it can be reached quite rapidely.
thanks
Regis
doesn't matter. even if you did configure each sat for ku high/low or C and Ku band, theres only around 10 sats or so up there with FTA (maybe a few more). So if you have 64 slots, thats only 20+.
Hi,
If I use the Al Satellite Alignment, it is a free software and enter my latitude and my longitude it generate me the following list: (see below)
thanks
Regis
N Satellite Position Azimuth Elevation
1 Telecom 2A 3,0°E 99.50 ° 0.51 °
99 AMC 8 139,0°W 251.75 ° 8.48 °
100 AMC 7 137,0°W 250.18 ° 9.84 °
101 AMC 10 135,0°W 248.58 ° 11.19 °
102 Galaxy 1R 133,0°W 246.96 ° 12.53 °
103 AMC 11 131,0°W 245.31 ° 13.86 °
104 Intelsat Americas 7 129,0°W 243.62 ° 15.17 °
105 Galaxy 13/Horizons 1 127,0°W 241.91 ° 16.47 °
106 Galaxy 5 125,0°W 240.16 ° 17.76 °
107 Galaxy 10R 123,0°W 238.37 ° 19.02 °
110 Anik E2 118,7°W 234.40 ° 21.67 °
111 SatMex 5 116,8°W 232.58 ° 22.81 °
112 Solidaridad 2 113,0°W 228.82 ° 25.00 °
113 Anik F2 111,1°W 226.87 ° 26.06 °
116 Anik F1 107,3°W 222.85 ° 28.08 °
117 AMC 2 105,0°W 220.32 ° 29.23 °
118 AMC 1 103,0°W 218.07 ° 30.19 °
120 AMC 4 101,0°W 215.76 ° 31.10 °
122 Galaxy 4R 99,0°W 213.41 ° 31.97 °
123 Intelsat Americas 5 97,0°W 210.99 ° 32.78 °
124 Galaxy 3C 95,0°W 208.53 ° 33.54 °
125 Intelsat Americas 6 93,0°W 206.02 ° 34.24 °
126 Brasilsat B4 92,0°W 204.74 ° 34.57 °
128 Galaxy 11 91,0°W 203.45 ° 34.88 °
129 AMC 3 87,0°W 198.20 ° 35.97 °
130 AMC 9 85,0°W 195.51 ° 36.42 °
131 Brasilsat B3 84,0°W 194.15 ° 36.62 °
133 AMC 5 79,0°W 187.27 ° 37.34 °
134 SBS 6 74,0°W 180.28 ° 37.59 °
136 AMC 6 72,0°W 177.48 ° 37.56 °
137 Nahuel 1 71,8°W 177.20 ° 37.55 °
138 Brasilsat B1 70,0°W 174.68 ° 37.45 °
139 Brasilsat B2 65,0°W 167.76 ° 36.87 °
140 Estrela do Sul 1 63,0°W 165.04 ° 36.50 °
141 Rainbow 1 61,5°W 163.01 ° 36.18 °
143 Amazonas 61,0°W 162.34 ° 36.07 °
144 PAS 9 58,0°W 158.37 ° 35.29 °
145 Intelsat 805 55,5°W 155.14 ° 34.54 °
146 Intelsat 707 53,0°W 151.97 ° 33.68 °
147 Intelsat 705 50,0°W 148.28 ° 32.54 °
148 PAS 1R 45,0°W 142.39 ° 30.38 °
149 PAS 3R 43,1°W 140.24 ° 29.48 °
150 PAS 6B 43,0°W 140.13 ° 29.43 °
151 NSS 806 40,5°W 137.37 ° 28.18 °
152 Telstar 11 37,5°W 134.17 ° 26.60 °
153 Satcom C1 37,5°W 134.17 ° 26.60 °
154 Intelsat 903 34,5°W 131.08 ° 24.95 °
155 Intelsat 801 31,5°W 128.11 ° 23.22 °
156 Hispasat 1C, 1D 30,0°W 126.65 ° 22.33 °
157 Intelsat 907 27,5°W 124.29 ° 20.82 °
158 Intelsat 905 24,5°W 121.54 ° 18.96 °
159 NSS 7 22,0°W 119.32 ° 17.38 °
160 Intelsat 901 18,0°W 115.87 ° 14.78 °
161 Telstar 12 15,0°W 113.37 ° 12.80 °
162 Gorizont 32 14,0°W 112.55 ° 12.13 °
163 Atlantic Bird 1 12,5°W 111.34 ° 11.13 °
164 Express 3A 11,0°W 110.14 ° 10.11 °
165 Atlantic Bird 2 8,0°W 107.78 ° 8.08 °
166 Telecom 2D 8,0°W 107.78 ° 8.08 °
167 Nilesat 101, 102 7,0°W 107.01 ° 7.40 °
168 Atlantic Bird 3 5,0°W 105.47 ° 6.03 °
169 Amos 1, 2 4,0°W 104.71 ° 5.34 °
170 Intelsat 10-02 1,0°W 102.46 ° 3.27 °
171 Thor 2, 3 0,8°W 102.31 ° 3.13 °
OK
Just got a 33 inch dish ...
No room for a 6 foot one !
thanks
Regis
I just checked and east of Echo 3 (61.5), the only ones that have KU band to the US are
PAS9-58
T11-37.5
Hispasats-30
T12-15
everything else is either C-Band or not aimed at US/Canada
Hi,
I just check and My tree hide 90 degree West up to 140 Degree West!
So if I'm right I do not miss much, I hope.
thanks
Regis
Sathawk 3000 whats so good about it, and how will this help me
Help hooking up my sg2100 motor
