Would some one please explain how to use/configue diplexer to share the same RG6 cable for satellite and cable TV signal? Thanks,
To start, you need 2 of them.
Sat LNB ------------\......................................................./------------Sat In
............................Diplexer --------shared RG6----------- Diplexer
Ant Roof -----------/.......................................................\------------Ant In
"So the bottom line is the L goes to L and....."
Where are you getting H, L, & S from?
Here's a diplexer on the Sadoun site.
Click the little drawing and see bigger copy of wiring diagram.
Here's a diplexer on the DishStore web site.
Click the photo, for a close-up view, where you can see the wiring info on the part.
But be advised, you don't get something for nothing.
There will be a reduction in both OTA signal and satellite signal.
If you can still work under those circumstances, then a diplexer might be useful.
Sat is High Freq - up to 2100 MHz
Ant/Cable Freq up to 950 MHz
Limited time offer
