You can't combine the OTA signal with the satellite signal with a Hopper.The OTA module has nothing to do with a diplexer. I need to get the signal from the OTA antenna on the roof next to the dish.
How? A diplexor splits the signal approx the 900mhz. Dish Moca and OTA both live in the area below that.You can diplex it with the line for the Joey, if you have one. If not you need to run a separate coax.
Yes, they split the signal at 900mhz. Above for SAT, below for OTA. Both moca and OTA live in the below range.Duplexes are used in pairs, one combines the signals the other splits.
You can diplex from the lnb and ota down to right before you plug into the node. From there you have to leave the host line clean
Limited time offer
