Diplexer, OTA Antenna question | SatelliteGuys.US
ibskiing
14
DT Stations: Abilene, Tx
yellow - uhf 114 degrees 13.8 miles
yellow - uhf 148 degrees 7.2 miles
green - uhf 270 degrees 18.5 miles
red - uhf 114 degrees 13.4 miles
I can receive all these stations fairly well with an indoor antenna
Two Questions:
1) Can I mount an antenna next to my satellite (Dish 1000 - on order) and use a Diplexer to carry the antenna signal along with the dual satellite signal going to my receiver (622 - on order)? I'm trying to avoid string any more cable!!!:mad:
2) Any antenna recommendations?:confused:
Welcome to DTV. My 622 is sitting on the table waiting for the installer.
If you have a good strong signal you can diplex your OTA signal, but it is not the ideal situation because there is a 2-3dB loss in each connection.
