DIPLEXERS problems | SatelliteGuys.US
DIPLEXERS problems
This1
261
Florida
I have a question about using a diplexer with aHR22-100 and slimeline dish pointed at 99/101/103/110/119seems like when I have them connected I receive low signal onthe 99/103 sat some very low and some at 0 so is there a better oneout there or not capability with this HD singal
My setup
>>>>>>>>>>>>>>>Switch –sat..............................................Switch –sat---Band_converter--box
SAT--Multiswitch_____ _______________________
>>>>>>>>>>>>>>>Switch—Cable_tv......................................Switch—Cable_tv-----to tv
Sorry, can't make heads or tails out from what you have with your post.Officially Diplexors are not supported when using a Ka/Ku dish/config. The unofficial is if you do it like:
dish output - > b-band converter -> diplexor -> cable run - > diplexor - sat box/tuner.
I used to do that using OTA feed, you say cable feed in your post which might be a problem.
Yes got comcast cable limited basic makes my internet cheaper...LOL
I thought they were same freq..
so put the b-band after the mulitswitch I will go try that
Local DMA for 64772?
Question about free starz
