Direct TV DVR in Motor Home | SatelliteGuys.US
GeraldR622
3
Colorado
I have a motorhome set up with HD TV using a HD receiver/DVR. Using a automatic locating antenna on the room. Works Great. When at home the motorhome is parked under a overhand. The roof antennas cannot be used. I had a single cable installed with an input jack available in one of the bays. The antenna signals are run to a 4 X 8 switch. There was physically only room ro run 1 cable which is now feeding tuner 1. I have a signal level 0f 99%. I cannot get past the set up display because it is looking for a signal for tuner 2. which is obviously not connected. I wanted a signal to the receiver so I could keep it "alive". It would be nice if it could be viewed also.
Question - Can I run the one cable to a splitter and run the 2 outputs to the Direct TV receiver? One to tuner 1 and the other to tuner 2.
any input would be appreciated.
GeraldR622
You have to change the system settings to tell it you only have a single tuner connected. You cannot split the signal and run a line to each tuner. Once you change the setting you should be fine.
Good call Wild Bill.
I've been in the same situation the OP is talking about before !
Though were not sure about his dish set up as he didn't mention which one he has, he mentioned a 4x8 switch makes me believe that he's not using the newer Slimline set up, so he won't be getting all the HD he should get.
Hey - Thanks guys. I give that a try
By the way I have the Direct TV Slimline Dish.
In your home or for the motor home ?
Are you going to use a Slimline also for the motorhome ?
If you can set it up ok, I would recommend going with the Slimline this way you won't have to make any changes from home to motor home.
IF you get one , practice at home before you go out and get it down pat.
Programming AV1 & AV2
Add Me To The Party!!!
