Direct TV remote code for Vizio TV | SatelliteGuys.US
yogiyawns
East Coast
I read on another post that that maker for Vizio is Samsung. I tried the last code on the Direct TV list under Samsung /and it worked perfectly for the vizio tv . Hope this helps. :up
10864, 10885, 11499, 11756, 11758 are all codes in my nifty little universal code booklet for Vizio TVs. If those fail, try code 10178 as well. That's worked on most Vizio's that other techs have failed to program for customers.
vizio t.v.code
was having problems getting my vizio to work with my D* remote until i programmed code 11758 which is not listed in the setup menu now my t.v. works hand in hand with my remote....thanks for the codes llisted in a previous post
FOX HD 399 Is On Now
Connect 2 DVRs to one TV
