Direct tv tivo dvrhd34 Record ? | SatelliteGuys.US
sportman13
352
4
I have direct tv tivo dvrhd34 reciever when I go to ESPN a popup message comes up record can not get rid of it do you know where I can get rid of it ?
raoul5788 I go to ESPNS a popup message comes up to record this episode of any sportscenter I I can not get rid of the popup message do you know where I can get rid of it ?
Yes did not work keeps appearing it says on any ESPNS a popup message comes up to record this episode of any sportscenter I can not get rid of the popup message do you know where I can get rid of it ?
No I don't. Have tried calling customer service?
Chip, not yet hoping someone here knows you know anyone here will know
Maybe. I think there is something in the menus about suggestions. Can you disable it?
Chip where do I find about suggestions in menus I heard you have to setup 5 series to record.do not get know if setup 5 series to record.is
dtro77 I am a disabled person not a great Typer I heard you have to setup 5 series to record to make popup go away ?
Yes, that is correct. Once you have 5 series set to record, the popup will stop.
To set up series to record, open the guide, highlight a series you like, and press the record button.
Once you have 5 different series set up to record, no more popups.
dtro77 I am a disabled person I get 5 series set to record, and the popup will stop. what is confusing is do I record one episode for each of the 5 series and the popup will stop.
Lanarian I am a disabled person 5 series set to record, and the popup will stop. what is confusing is do I record one episode for each of the 5 series and the popup will stop.
Has directv made improvements with their signal?
Nielsen changed local channel area - get my local channels back?
