DirectTV HD problem | SatelliteGuys.US
DirectTV HD problem
onefoxalpha
5
Hey there.
I am wondering if someone has an answer or me because I cant figure something out.
When I record an High Def television show on my DVR and then want to watch another HIgh Def show on a differnet channel, it says "searching for signal."
Basically, I can not watch any HD shows while another is recording, or record two HD shows at once.
I can record two standard def. shows at once without a problem. Also, lets say I can record a HD program and watch a standard def show on another channel.
I called Direct TV they had no good answer. What should I do. Thanks for the help.
Hey there.
Quick note, you will get a faster response by posting this in the Directv technical questions or DirecTV forum.
Wow... that's interesting.
The only thing I can think of is maybe you have 1 bad B-band converter or something is wrong with one of the wires leading to your HD-DVR
Go into the setup menu and check the signal strengths on the 99/103 for both of your tuners... If one of them does not have a signal that is your problem.
If that is the case it can be a range of things... bad converter, bad wire on one tuner, or even one bad HD tuner.
There is only one other thing I can think of at all... maybe there is a splitter in the line somewhere causing a voltage problem/switching problem.
I am having this same exact problem. After some looking at the signal strengths I did notice that tuner 2 had 0's across the board for the 99 sat. I grabbed a b-band converter from my other HR22 and voila no more problems. I talked to an installer I know who said they've had some bad b-band converters, and that's exactly what you'll see. Now I'm waiting for a replacement converter.
You should check sat 99 on both tuners. I'll bet you'll see one is all zeros. If that's the case call DIRECTV and get a new b-band converter.
It's official... Price Increase!
Sign a petition and keep Monsters HD on the air.
