Someone threw out a Directtv slimline in my neighborhood so I figured I would give it a shot. So purchased a lnb bracket and a spitfire .1db lnb. I drilled a new hole to mount the lnb bracket so that it aligned with where the swm3 that came on it was. Tightened everything up and pointed to the sky and was able to get pretty good signal. I picked up all transponders on 97W anyway. Then I moved to 101 for the Biography and History channels. I posted picks for anyone that might be interested in it. Check out the laundry basket (held down by 25lbs of sand) mount. Oh and not that it is related but I scored a Coolsat 7000 micro PVR for $10 of Craigslists....and yes it had modified firmware
but I got her on the straight and narrow now...lol.
