Do you even know what a phase 3 dish is? There are no DISH LNBs that would fit on it.abricko said:The Antenna is fine... make sure you use the right (DISH) LNBF though
boba said:Do you even know what a phase 3 dish is? There are no DISH LNBs that would fit on it.![]()
For what its worth I've been told it will work, but you would have to point it differentlyecarl4100 said:A Friend gave me a Phase 3 Directv dish antenna. Is it at all compatible with dish ? (I've got a 301 reciever) If it'll work, I'll try it at my RV to use on weekends. Thanks
abricko said:I should've said, it's not ideal to use it, and yes I have seen a lot of crappy mods... but they work (for how long, who knows)
Limited time offer
