Just making sure I'm ready to make the jump. Currently with Dish, I have 3 RG6 cables running from the dish to a switch to feed the receiver. I need to know if I need to run a 4th RG6 to the switch for a SWM8 switch.
Why not let the installer run it? I ran these 3 cables and they can barely be seen from outside. I hid them pretty well and I would like to keep it that way. Plus, Directv uses white RG6 cable which I dislike. I will be getting the core programming, spanish programming and HD. I will be getting 1 HD-DVR, 1 SD-DVR, 2 HD receivers, and 2 SD receiver for a total of 8 tuners.
Can they install the AU9-S-SWM-B-PWS Five LNB Ka/Ku Slim Line Dish (sorry for the long name) and just run one cable inside to an 8 way splitter? or can they install the same dish and use two of the lines to 2 4 way splitter? or will they install a 5 LNB dish and run 4 cables to a SWM8?
Just learning how Directv dishes and switches work now.
