What kind of equipment ?Friend moved and gave me his directv equipment. What should I do with it?
You turning the recvrs in won't do him any good, he would have to return them so they are taken off his bill .... usually you have 7 days after the boxes are delivered to return them, otherwise they bill you like $400 for each recvr.He's gone. Can't give the stuff back. Should I just call Directv and have them come pick the unit up?
Look behind the little access door, it will give you the model number.I don't know the model. It is the unit that hooks up to the tv, a remote, and a dish that sits on the ground.
They will DEFINITELY want that recvr back .... and you can't activate it anyways.On the bottom it says HR54-700
Limited time offer
