DIrecTV International Dish | SatelliteGuys.US
azlid131
Hi everyone. I am first time on this forum, thanks to everyone who can help me to resolve my problem. I have DirecTV international dish 95W & 101. I want to know tjhe best way to set up this dish to get russian channels from 95W. I want to use this set up on the go from RV on different locations. What type of additional equipment I might need to do it right. I used som esignal finder from RadioShack last week- did not help.
Thank you for your help!!!
You may want to consider a professional meter. There are several recommendations for using the Birddog.
You will need a good tripod.
if that is to only dish you are using ... you need to point to the 101... then the 95 should just happen ... might have to peek the 95 a little ...
just set all settins as directed by zip & it should work ...
Satellite Question ?
SWM compatible diplexers?
