Directv Locals 25320 | SatelliteGuys.US
PKII
791
19
WV
I tried to find this answer on the directv site but I got lost. :confused: Are locals available to zip code 25320 also which satellites are they on? Positions.
When I print out a channel list for my zip code at the top it says no locals available but at the bottom of the list it prints locals. :confused:
Yea, D*'s website is now a MESS trying to find some of their crap out, particularly local channel info! It took me forever to find a place to put in your zip code, instead of my current one.
Try this link instead: (note that it asks which county you're in, but it appears the same either way)
http://www.directv.com/DTVAPP/packProg/localChannelsFragment.jsp?assetId=900018&_requestid=2336188
According to what I pulled up, you qualify for the Charleston-Huntington locals:
Network Affiliate Local Channel # HD Channel
NBC WSAZ 3 3
ABC WCHS 8 8
FOX WVAH 11 11
CBS WOWK 13 13
PBS WOUB 20
PBS WKAS 25
CW WQCW 30 30
PBS WPBY 33 33
The SD locals are on 119 & the HD locals are on 103, so you'll automatically get a 5LNB slimline installed if you get HD
(you'll only get a P3 oval dish if you are ordering SD only)
upgrade receiver with a new hd receiver
CinemaPlus question
