Directv locals | SatelliteGuys.US
Directv locals
PKII
791
19
WV
I currently have dish network. :D
My question is which satellites provide local programming to the area of Charleston WV 25320 is the zip code here.
The reason I ask is Dish moved all its locals from the satellite at 105 degrees which I could pick up fine but moved it to 129 where all I can see is trees. :(
Which satellites do Directv use for my area?
Of the satellite arc I can clearly see from 72 W to 119 W I hope directv uses something between those. :)
Of the satellite arc I can clearly see from 72 W to 113 W I hope directv uses something between those. :)
Your sd locals are on the 119 satellite. Hd isn't available yet, but when it is, it will be on either 99 or 103.
That sounds real good. I'll think I wait till HD is available. :) Thanks.
Glad to help. It could be a while before your locals are in hd, likely not until late in the year or next year.
Chase Carey Leaving DirecTV?
Turne2 not working (Extending cables)
