Discovery moved? It is no longer on 278?Ok, I searched and couldn't find an answer.
Why is Directv moving channels? SpikeTV moved a couple weeks ago and also the Food, Discover and some others.
They screwed up some of my recordings
I guess its all been said above:
1. They are re-grouping the channels to be in their correct category.
2. This re-org will also likely open up some category space for any new channels.
3. BRING on the moves; I am still praying to get the PPVs moved out of the 100's.
3. Some chnls will likely not be moved regardless of their actual content category because they hold contractual agreement to be placed in certain assignments; be it by number or within a particular range.
Ramy,
The move should not have messed with your recordings unless you did manual recordings, the HR series is suppose to be able to locate according to title, this way when it moves to a different channel , it follows, also suppose to work for a show changing dates or times .
Jimbo
Series recordings are based on the channel you pick to record your show on. Series will not record that show on another channel number so if the channel number is gone the series will die.
So if a show I record every week, changes networks it will not follow it ???
That contridicts what I was led to believe when the HR20's came out
Jimbo
If that were true you would have had whatever show you record recording on all channels. Say CSI for instance. It is on CBS and also other channels and it would record all them if you told it to but it doesn't work like that.
Limited time offer
