Directv Phase I dish with Dish Network 4000 receiver? | SatelliteGuys.US
nova72
3
NY
Hi, I have an Dish Network 4000 receiver currently working with a single lnb Dish 300. I'm trying to get the receiver to work with a Directv Phase I dish with a dual lnb. I can pick up Dish 110 but not 119 which is what I need. Any reason why this will not work?
Are you trying to aim the D* dish for 119 and use the dish 300 for 110? If yes both will need to be LEGACY LNBs you may have a DP on the dish 300 the D* dual is LEGACY. You will need a SW21 switch to combine access to both satellites after you have both dishes correctly aimed.
YOU REALLY REALLY NEED TO REPLACE THAT 4000 311 or newer 211 preferrable.:)
Thanks for the reply. I want to use the D* dish by itself pointing to 119W with the 4000 receiver for a temporary setup. The existing 300 dish that works with the 4000 receiver is a single lnb. I can get the D* dish to pick up 110W but nothing when pointed to 119W which is what I need.
????????????????????? Still don't understand what you are trying to do. Aim the dish 300 at 119 and the Directv at 110.
BBC America no world news
Is alacart even feasable?
