i am having Directv installed in a couple of weeks. I know most of the requirements, but I don't know what size pole to use. Can anyone help?
Or a Fence company will also have them.Same as directv.
Forget Trying to find the right size pole at Home Depot.
The only way you're going to get the correct size pole is from a DirecTV or exceed installer or authorized distributor or dealer.
The 16 foot pole I am using I got from a fence place. 2 inch they have, as you mentioned, it's slightly smaller 1 7/8 th I think.You would think but they only carry 1 5/8 and 2 3/4
There is a 2 inch size out there but it's just slightly smaller and then you have to to use a self tapping screw to prevent the dish from spinning on the pole.
You can tighten down the bolts all the way, and the dish will still spin on the mast if your not using the official ones.
nobody said anything because nobody wants to replace it haha.
Limited time offer
