DirecTV TiVo THR22 Control via IP? | SatelliteGuys.US
cpalmer2k
1,097
696
United States
A few months ago I came across an old article originally written for SageTV users that provided an application called "dtvtune" that allows you to change channels on DirecTV set top boxes via IP. This has come in handy for me with our Genie.
My question is can you also control the DirecTV TiVo THR22 with the same technique, or does that not work because of it being TiVo powered? Would someone out there with a THR22 be willing to try it out and see if it does work?
Here is a link to the original article/download
I should have added that "part C" of that post on the link I provided is the relevant portion:
c. dtvTune.exe: This is the executable that actually sends the channel change request via HTTP to the STB. This is called from the DirecTVMultiChg.bat file and should be installed in your SageTV\SageTV directory. The command line usage is
dtvTune.exe -ip <IP address> -channel <channel number>
Directv App Issues
DirecTV's 1st Quarter 2018
