directv vs polaroid LCD remote codes | SatelliteGuys.US
b-andre8
2
Has anyone programmed a Polaroid FLM-1911 to the directv remote??I have called dtv and e-mailed Polaroid,no responce yet, I have used about 13 codes,all the remote does is if you push volume down it changes the caption option on the tv,, but no volume,or other functions!!
I also have that TV, and I have had no luck in programing that with my remote. I have read some reviews on that TV, and some of the criticism has been with issues such as that along with some others that escape me right now. I do like the picture, so I guess I'll live with it.
"All in One", Model URC-6131.............its under $30.00 at Best Buy/Circuit City........This operates everthing I have.............( and that is a lot of equipment)
You can always try emailing Polaroid and asking if codes from another set will operate the unit.
Thats how I found a code for the LG flat panel I have. When I emailed LG they told me to try a Sony code, it worked.
Thanks for all the help with the Polaroid,,BUT,, I decided to trade it back in when all I tryed failed,, THANKS,now it's not a problem!!!
Currently have HR20 and 3 LNB
Receiver Tracking Question
