If you are connected to the internet use the right arrow button.
That should pull up the list of apps.
They can also be accessed by going to: menu>apps>launch TV apps.
As mentioned, with internet, arrow to the right, apps load and Weather is one of them, from there go in and select the cities you want.
Then you can get the local temps as well as a forecast.
