DIRECTV2PC and VPN adapters | SatelliteGuys.US
michaelbudney
193
I was receiving the following message when trying to view recorded shows:
DirecTv2Pc cannot connect to the server.
The protected content cannot be played back at this time.
I did have one recording that would play back and that was the HDNet test pattern.
I found this post DirecTv2Pc and ICS Internet Connection Sharing - DBSTalk.Com about VPN adapters causing the issue. I was able to go in and disable the adapter but this is not an ideal solution.
Is there a reason playback is not supported when there is a VPN adapter? I assume this must be a protected content issue of some sort.
Support for up to 8 remote controls IR codes (instead of 2)
MediaSare just dissapeared
