Directv2PC | SatelliteGuys.US
Directv2PC
csabec
85
UP of Michigan
Anyone else having trouble with Directv2pc? I have had it on my pc for about a year and never any problem. Yesterday I went to use it and now it says that I have to Re Activate the key. So I uninstalled it got a new code from Directv and then reinstalled the software using the new code and I can see my receiver and the RID and I click connect on the software and it tells me to make sure that I have the internet on and doesn't authorize it. I did check and make sure the receiver was connected and I can see everything on my network. Anyone have anything I can try to fix this? Thanks for the help.
Thanks for the response. I did check my anti virus and windows firewall to make sure it wasn't blocked. The Directv2Pc shows up in my Network Devices so I am not sure why it's not working. It might be something to do with the new HD Guide but I am not sure. I will post in Directv Tech help forum to see if they have any fixes.
Recordings view in new HD GUI
Super Bowl mirror/feed channel
