Hello! Does Directv's HDDVR record OTA programing? Thanks!
However people have been posting issues with recording OTA via the AM21, so if you definitely want to record OTA I would defiantly acquire your own HR20 from D* (if you can get them to Drop Ship), Best Buy, Circuit City, Sams or one of this sites sponsors.
No plans. BTW:I've had a AM21 on my HR21 for months (as part of the early test program). The issues I've had with it are sometimes the trick play (30sec skip, skip back, FF, RW) are slow to respond on ATSC recordings. The other issue is that sometimes when going to black between shows and commercial breaks there might be some blocks carried over from the prior scene for a 1/2 sec or so. Both of these problems some and go depending on the CE version of the software I've got loaded. The latest CE isn't doing this, have to wait to see of the new release that started going national also has the fixes. But other then that the AM21/HR21 hasn't failed to record what I wanted it to do.This is a pain in the A@@. Do they plan on having any new HDDVR'S soon that will record OTA? I used to have E* but currently have nothing and was leaning towards D* but I would like the ability to record HDOTA like you can with DISH'S DVR. Any ideas? Thanks!
Limited time offer
