Direcway Dish For DN | SatelliteGuys.US
Mattman71
14
Texas
I recently found a Direcway/Hughesnet dish in the garbage behind a local store. The dish itself is about 39"wX23"h. After an inspection, the lnb looks a bit corroded and has a little moisture inside. I removed the transmitter/lnb parts, and am going to set up my new dish
Not exactly high tech, but looks functional. My hope is to eliminate a little of the rain fade that I currently have with my Dish 1000 setup. Having never done this, I am curious about the type of lnbs that I should purchase that will actually work with this dish. Does anybody know if I can just buy universal lnbs like the Spitfire KU Elite, or do I need something DN specific?
Thanks in advance.
the dish 1000 will work better then that set up IMO. if you were to use it for one sat location you MAY see a little extra gain. that dish is tweeked for it's original application.
if you do want to try it you will need circular lnbs and depending on what switch you use propably dish pro lnb's with the covers removed to allow that type of mounting.
I agree with the mack
DBS does work on it for one satellite but its hard to get 3 on it properly due to to the focal point being off
Here is a pic I had with a DIrecPC dish (same type)....the gap between LNB's is huge
in the pic I had used it for free to air for 95 and put 2 LNB's for 91 & 82 for my (at the time) bell ExpressVu subscription but to get both 91 & 82 to work I had to put a dummy LNB in between (see pic).
I had done it at the time to combine 2 dishes into 1...I didnt gain any points
722 rebooted during bad weather
Lost satellite signal message won't go away!
