Direcway questions. | SatelliteGuys.US
Direcway questions.
dfergie
Proud Staff Member
Staff member
HERE TO HELP YOU!
Ok installers, what type of cable comes into your house into the direcway box, RG6? and will the direcway when used with d* receiver get 101, 110 and 119? And what sat. is the direcway using? Thanks... (live in the country, no dsl ava for a longwhile, no cable int. for awhile )
When we install DirecWay, we always use quad-shield RG-6 coax. Better protection from interference. I recommend using a seperate tri-mode dish for your DirecTV receivers to pick up from 101, 110 and 119. Accuracy is essential in aiming the DirecWay dish. I haven't seen a "sidecar" that is tri-modal.
Most DirecWay systems are on SATMEX-5 or GE-11.
