DIRT Members online | SatelliteGuys.US
DIRT Members online
The DIRT members are invaluable here. Do note though that there are some things that they just cannot do or have control over.
If you seen the picture http://www.satelliteguys.us/attachment.php?attachmentid=64889&d=1304659604, then you perhaps noticed a diagram in a middle with TWO lines to a dish.
I would rather to hear from DIRT member a correct info.
But if you would have looked here http://www.satelliteguys.us/attachment.php?attachmentid=64892&d=1304659665you could see that the diagram is the same. and the arrows on the left side of your pic say to ODU and points to 3 ports whereas on the solo node they only point to two.
The reason I am posting this is because you seemed to come across as an a$$. IMO that is. if you are going to try to prove someone wrong then maybe you should look and be sure you are correct. With my argument i have thus proven they probably used the same picture for the two nodes. just added more to the outside to label the ports. The diagram seems to just allow the installer to get his bearing when mounting the device. And i'm sure a dirt agent will be able to get the info. they know who to ask but for a product that hasnt released yet and only in houses of a few beta testers i'm pretty sure they are either not going to be able to get a straight answer or it will be same as mine and thekrell
Stopping service ?
Installer here now - 1000.2 vs 1000.4
