my dvd player built into my tv would not play the disc and it won't eject either. i guess the dvd player is shot. what do i do? i don't wanna have to pay for a disc that is stuck in my tv that is not of my doing.
i've tried that and it didn't work. i cannot find a way to open it manually. but, i will google it.Unplug the TV for a minute and then plug it back in. That might just fix it. Oh, and by the way, it is your doing, you put it in your DVD player, nobody else's fault.....
Also, most DVD payers have a way to manually open them when they refuse to play or unlock....
paper clip in a little hole? and wow! i didn't make the dvd player conk out.Well, it's your TV for crying out loud! You can either find out how to eject it (paper clip in a little hole?) or pay for the disk since you still have it.
Hit it with a large hammer?OK, how did you get it out if there is no little hole?
i kept hitting the eject button and it finally popped out. when i hit the eject button i could heard stuff inside running and it finally popped it out.Hit it with a large hammer?
Limited time offer
