Diseqc 4x1 and Diseqc 1.2 acuator ? | SatelliteGuys.US
sikma
408
Dish Farm Up North
I worked out a deal with Cascade for his polar mount and Diseqc 1.2 actuator. My question is, can I run my RG6 coax from the acutuator through my Diseqc 4x1 swith then to my receiver? I ask this because I'll still need two dishes, one with the motor for 74-103 birds and one P* dedicated for 123.
Did I read in another post, that if using an actuator then running the RG6 into a Diseqc 4x1 switch you should connect the switch between the lnb & motor then from motor to receiver?
You can have switches before or after the motor. Diseqc 1.0 or 2.0
What exactly is the equipment you are running?
Do you know what switch setups your receiver allows?
Saying Thanks
Usals
