Does anyone know of a DiSEqC command that is the same as pressing the reset button on a motor to reset/re-zero the motor (SG2100 or SG9120)?
Thanks.
Thanks.
if it doesnt move to anything but 0° then there is something wrong.
HARDWARE RESET
1. Make sure the power from the receiver is turn -on. The indicating LED lights on.
2. Drive the motor to 0° via the manual button.
3. Probe the RESET button behind the bottom of the motor via a thin rod for 2 seconds. The LED
blinks in Orange Color. The reset process is OK while the LED is green. The preset Satellite
Table will be re-install and the current position will be set as 0°. Please cut off the power for the
motor first before any operation.
I am trying to fix that when it happens. (Example - The motor moves to 1° instead of 0°, I want to drive the motor back to 0° and reset it)
Below is from the second PDF.
I guess I am looking for the DiSEqc command that does the following: "The current position will be set as 0°".
Limited time offer
