Diseqc switch 8 in 1 | SatelliteGuys.US
coathanger
43
Can anyone tell me how to get my rec. to recognize this switch in antenna-setup? I have afortec classic, and cw 600p. Both rec show only 1 thu 4 lnb in antenna setup. Any help appreciated.
If those receivers don't have 1.1 diseqc commands, you will have to set it up for 1.2 diseqc commands. Unfortunately, I haven't done that yet, so Iceberg (or someone else) will have to help you with that info? I'm now waiting for that answer myself!
Al
which 8x1 is it>?
The digiwave one is uncommitted and you NEED to have Diseqc 1.1
The others (Emp Centauri is one) will work with Diseqc 1.2
Tnx for reply Iceberg,Its a DGS-SW8by1 multiprocol programmable Diseqc 1.1 By Digiwave.
v box 11
Satellite segment - Wired Science on PBS
