diseqc switch ? | SatelliteGuys.US
diseqc switch ?
joem919
161
myrtle beach
ok i have the invacom0.3db lnbf,
my question how do i set this settings
for l n r and h n v .
I have the diseqc 4 n 1 switch .
thanks for any one who responds on this and their help
There is a thread in the FAQ section concerning use of diseqc switches.
Many examples are shown. Does that help?
There are two common Invacom LNBs we use.
- the SNH-031 is Universal and linear only
- the QPH-031 is Standard and linear, AND ALSO Circular with a different LO
links above take you to the Invacom site, where you can find PDF documents for each LNB.
Basically, the QPH is Standard; LO= 10.750, and on the other port Circular; LO= 11.250
The SNH is Universal, with dual LO of 9.750 for low band with 22khz off, and 10.60 high band with 22khz on.
Twinhan and USALS
Pansat Remotes
