Dish 1000 quick question | SatelliteGuys.US
Briant73
SatelliteGuys Guru
148
5
Pennsylvania
I was checking my dish1000 right before winter to make sure everything was ok and set for the oncoming season and noticed something with the 110 119 lnbfs.
The dual unit seems to have some play and rocks a bit back and forth. I checked the screws and they are tight so not sure why it has the play or is this normal? I guess my main concern is during times where it's windy while this adversely effect my signal or be a structural concern.
main reason is the yoke (the Y adapter or in this case maybe the W adapter) isn't molded to the unit so there is a little rocking
921 Recording @ wrong times?
Uplink Activity Thursday Nov 10th 2005
