Dish 1000 to 622 question | SatelliteGuys.US
trido
440
17
Southern indiana
I am confused right now I have a dish 1000 to one vip211 box one set thats all.
I madea big mistake and should have got a 622. I had that all I needed was to put a separator in line at box but read this and am confused.
I want to stay the ONE line only from Dish1000 to 622 (like to current 211)
Wont be running another set be is single mode only for 622.
DO NOT ORDER THIS PART (DISH PRO SEPARATOR)IF YOU DO NOT HAVE A DISH PRO PLUS 44 SWITCH. IT WILL NOT WORK WITH A STANDARD DISH PRO TWIN LNB.
thanks
Trido
If you have a Dish1000 to just a 211. Then you have a DPPtwin and a DP dual on the dish. This LNB setup will work with a DP seperator.
So yes you can have a 622 on that one line you have now.
Thanks Dave not sure why I am reading what the DISH store says that it wont work.
thanks again
trido
DPP 44 switch and DPP Twin are just what they say DPP or dish pro plus. They will both work fine with the seperators and one line run to the receiver.
drv 522
HD signal on SD receiver
