DISH 2 Receiver Setup | SatelliteGuys.US
Hunter Mackenzie
81
2
I have a question about a 2 receiver setup.....In my new apartment the people before me left a DISH 500 with the DP Twin that combines 110 and 119 into one cable into the apartment........I have a 722 and a 211k and will hook up a wing dish at 61.5......I also have a DP 34 switch......Now can I take the 1 cable thats there from the DP twin and the cable from the 61.5 slot into the DP 34 and then run 2 cables to the 722 for both tuners and 3rd cable to the 211k will this work?
Everything will work on the three receiver side and the wing dish is good but you need a second cable from the DP twin to the switch.
Replacing the DP Twin with a DPP Twin maybe the easiest. 61.5 would be attached to the input port on the DPP Twin and the 2 existing cables would go to the 2 receivers. The 722 would be connected with the separator instead of 2 lines.
what dishes are being installed in metro NY?
Early Termination fee
