Is there a splitter out yet that will spit the dish cable coming in so you dont need to run another dish cable into the house??
thiggin2 said:Is there a splitter out yet that will spit the dish cable coming in so you dont need to run another dish cable into the house??
Yes, it's called a stacker. But it will cost you minimum of $300 just for the hardware to join the signals. The yet-to-be-released DPP44 switch will do just this, but isn't available yet.thiggin2 said:Is there a splitter out yet that will spit the dish cable coming in so you dont need to run another dish cable into the house??
Check EBay for "Dishpro # way splitter" where # is the number of splits you need. There doesn't seem to be a huge difference between 2 and 3 way splitters.thiggin2 said:How much does it cost and were can I get one???
Limited time offer
