Dish 322 CATV jack..... | SatelliteGuys.US
OoTLink
731
I imagine this is a bit n00bish of a question, but what happens if you plug cable into that jack? Could I just hook our 322s up to that and let the TV2s hooked up via coax use cable via it? That could rawk :)
Are you talking about the ant/cable port? Yes you can run a cable co service line to it but you will only get that feed on tuner 1.
That sounds strange, because tuner 1/tuner 2 switch between TV1/2 all the time here. Are you sure you don't mean it only works for TV1?
Edit: Err nevermind that, I'll just use diplexers (one way instead of having one on each side of the line)
OoTLink: Van means TV1 ("output" 1, not tuner 1 - no 322 tuners are involved in watching the antenna/cable input).
Yes, too many people don't understand the difference between tuners and outputs, but it does NOT matter for a 322 except it's a bad habit to be in. ;)
Echostar To Offer Univision In Puerto Rico
TiVO and 322
