Dish 322 - IR for 2nd TV? | SatelliteGuys.US
trinidex
892
Hi guys,
I'm looking at a setup of a 322 and 2 displays.
I understand that the 322 2nd remote uses UHF not IR.
Thing is, this setup would use a Crestron touchpanel system, so I need to control the 2nd output with IR not UHF.
Anyone know if this can be done?
TIA
The second remote needs to see through walls as it doesn't have line of sight to your receiver. If you want to put in an infra-red blaster from your receiver to your second tv it could work, if you could label number one tv number 2, and I beleive the RF remote can be set RF or IR. Not sure the blaster would have on the unit in the other room. The best way would be to move your receiver.:D
What I'm trying to do is the other way around.
I want to control the receiver's 2nd TV output via infrared, not UHF - to change channels, access the Guide, etc.
Only sound - No picture on 622
All American Direct freezing.
