Dish 322 receiver on a boat | SatelliteGuys.US
Run a switch test on a dish that sees both satellites.. Then when you hook it to the boat dish it will show all channels. Just don't rerun the test once it's hooked to the boat dish. You do know of course that you are going to have lots of problems doing this.
What do you mean by "One can see 110 OR 119 at a time"? Do you mean that you have two of them? if so then just use an external switch(es). If the receiver sees them as legacy duals I would just use a pair of sw21 switches(one for each tuner).
Well I did not read the whole manual, but it looks like it is basically 2 legacy type LNB's. It would work ok for a single tuner using and sw21 switch. Not going to work so well for a 322.
NASA still free to air?
Why did I EVER Switch?!
