Dish 322 UHF signal not strong. | SatelliteGuys.US
2rk
We have two 322 receivers that connect 4 TV's. However, the TV in one of the rooms is a bit far away, and the UHF pro remote sometimes lags behind and sometimes we have to push the buttons two or three times to change the channel.
Here is what I tried:
-Replaced the batteries
-Moved the uhf antenna on the receiver in a horizontal position so its more in line with the room that is having problems. This helped quite a bit, but there is still a lot of lag.
-Called Dish, they said I would have to "extend" the antenna by adding in a coaxial cable and connecting the antenna to it.
The remote is a UHF pro which has 19945 written in the back. I searched these forums, and people are mentioning getting a "attentuator"? Or try changing to band B on the remote? Where is this band on the remote?
The thing is that I don't know what to try next, or should I be trying things in combination?
Thanks.
Thanks.
TV 2 help.
TV2 Tips & Tricks
Newb Install Question
ATT Question
