Dish 500 "Aiming" Problem | SatelliteGuys.US
tjcnole
15
Pensacola, Fl
:confused: I have a Dish 500 antenna with dual LNB's that is supposed to pick up 110 and 119 satellites. I get a great signal from 110, but I can't get a strong signal for 119. Can someone help me figure out the settings, (elevation, skew, etc)? I live in zip code 32514. I have tried adjusting the dish side to side and even a little on elevation, but to no avail. Thanks in advance.
Welcome to Satellite Guys..... :wave Is your skew set right.. for your area it would be an azmouth of 225 elevation of 43 and a skew of 128 if your skew azmouth and elevation is right on target.. then is your mast plum and level on atlest 3 sides.. if it is then you might be having tree issues.
problem recording using s-vhs player with 625
HBO & Showtime Free Preview Starting 9/3 @ 6AM EST
