Well first off I have a Dish 500 dish. No mounting pole as it was used for my Dish 1000. So it's just the Dish and arm. No LNB either. The Dish says JVC Dish 500 on it. I'd like to get $20 + shipping for this.
Next up I have a Dish Pro Quad LNB that was on my Dish 500. It had a piece of the corner plastic chipped off as you can see in your pictures. I bought it new and it came this way but I decided to go ahead and try it and see if it worked. Well turns out it worked fine like this so I just kept on using it. I used it for a while and never had a problem with it so it's just cosmetic. I want to say I used it for a year like this but it might have been a lot longer or a little shorter. I'm not really sure. For this I'd like to get $25 + shipping.
Here are some pictures of it.
I have more I will try to upload later or send me a PM if you want to see them.
