Dish 500, Legacy Model 3900 and DP Model 510 | SatelliteGuys.US
Kulaman
4
Waterloo Ny
Heres a question that has probably been asked before, but I cant find the answer i'm looking for.... I have a old Dish Network 500 dish connected to a sw21 switch for sattelites 110 & 119 to a Dp model 510 that works great. I'm trying to connect a model 3900 (legacy?) receiver to this dish. What is the switch I need to use this dish 500 with these two different types of receivers?
You could use another SW21 for the 2nd setup
Since you are using a SW21 right now (and its working) the LNB's have to be Legacy. Legacy equipment works with all receivers
110 output 1-------sw21 1 input 1
119 output 1-------sw21 1 input 2---------510
110 output 2-------sw21 2 input 1
119 output 2-------sw21 2 input 2-------3900
Do you have 2 dual LNBs or are they singles? If the existing LNBs are singles you could upgrade to a LEGACY TWIN or a Dish Pro Plus TWIN.
Do all Dish 500 LNb's have dual outputs, i'm not sure if I do or not? If I only have one output per LNB is this still possible with out upgrading my dish?
Does Dish downrez HD channels?
1002 Antenna and DPP44?
