dish 500 problems | SatelliteGuys.US
dish 500 problems
rmolder1978
5
tn
ok, ladies and gentlemen, i need help. i have a dish 500 with a dp lnb, it is mounted on the over hang of a house. i have a good clean signal of 89 to 119 but can't dial into the 110 dish. what am i doing wrong. i live in tn, the skew is 122, elevation is 38 and azimuth is 222. i had to put the dish at elevaton 41 to get 119. hope someone can help with this.
I put the Nashville zip onto dish pointer and got your exact numbers.
Check the mast of the dish and make sure it is exactly vertical.
Also cover the 110 lnb and be sure you are receiveing 119 on the 119 lnb and not on the 110 lnb.
If that is the case, turn the dish 10-12 degrees east and drop the elevation back to 38.
Follow above advice. If trees aren't a problem, settings or LNB failure could be the problem. Also check cabling and connections for moisture.
ok, guys thanks for all ya's help, i am going try to fix it as soon as it warms up, i think my biggest problem is that i mounted it an overhang on an old house and it moves way to much. so i am going mount it to the roof and try again. hopefully just moving it a bit and tweaking it will fix it.
When is the Dish press conference at CES?
VIP 612
