dish 500 setup issues | SatelliteGuys.US
clkdrywall
Elgin
I have a dish 500 system running through a dp 34 switch controlling 3 recievers. my issue is 2 out of the 3 are up and running on the 3rd I tested the switch it came back with 119 odd only I pput a new connection on the line and got 119 odd/even 110 odd any clues as to what went wrong???????? I am going to seitch the problem child onto a known working line to make sure my reciever is not the issue the line going to reciever 3 comes straight off the switch into the building and into reciever no splices. :confused:
swap rcvrs...cst on each. that will narrow it down to the room or to the rcvr. evens come over at a higher frequency, so your cable may be burning up. replace that and check switch, then have a tech out
Looking to switch to Dish, confused on a few things...
722K Freeze/Reboot Playing OTA DVR
