Dish 500 vs Dish 300 for 61.5 | SatelliteGuys.US
trido
440
17
Southern indiana
I put up an older I think they where called DISh 300(original 18" dish) for 61.5.
Signal sorta weak most TP around 78.
I put on a new Dish Pro dual LNB with it.
A customer of mine came in friday said he would give me a DISH 500 if I wanted, now he used it for 110,119 sats.
I think it has a TWIN lnb (non PRO )
If thats right and with my DP 44 switch I would need my new dual LNB.I think I can get a I adapter or some adapter needed to put my pro dual lnb on dish 500 arm.
So I guess the question is I think a 500 dish is a bit larger would I see any increase in signal.
Trido
dfergie said:
You should, you can put the Dp lnb on one side of the Y , set the skew to zero...
Ok thanks well I have not seen a Dish 500 but thought my dish pro dual lnb would not fit the Y with out an adapter.
My lnb looking at it is like D shaped if that tells anything
Trido
It is better to utilize the larger collector for 61.5 especially in the West coast. That bird just sits too darned low. I modified a 18" d* dish to fit a DP head and pointed it at 61.5 but fortunately it's only temporary. I know when it rains I'm going to lose it, but that's the price one pays when bird shooting is a hobby and not a chore.
Can an existing sub lease a 942
DVR 625 activation
