Dish 625 doesnt work | SatelliteGuys.US
Dishusercan
154
22
US
I just got a 625 dual receiver and on 119 I get transponder 11 to 21 and on 110 11 to 31 and I did the check switch and it says ok , I have a sw44 and port 1 is 110 and port 2 is 119 and when I try to exit of the point dish it says the signal you are receiving is not from the satellite you have selected. I already have a 222k and it is working fine but I can't figure our how to make the 625 to work Thanks
Do you have a SW44 or a DPP44 switch? Do you have 1 or 2 lines run to the 625? Give a little more accurate information and wr can try to help you. We can't see what you have so you have to be our eyes and tell us about the equipment.
Dish 625 doesnt work right
100.2 Sudden Death
