Dish 625 receiver | SatelliteGuys.US
Dish 625 receiver
No but that sounds interesting. I have never even thought of that.
ya know
i have a 200Gb hard drive and a ribbon cable from my computer which seems to be the same as the one used in the receiver,i figured i might try it to see what it would do im sure it will work . they slave hard drives off one cable so its a hard drive like a computer, and i build them so i there the same cable. i figured it'd give you more space. you could always make a bracket for it to fit.it it worked. you know
Comcast Sports Net HD in Chicago
A good CSR
