Dish 722 web activatio/dish remote access? | SatelliteGuys.US
gtjr92
47
I have had my 722 for a couple years now. Ever since they enabled remote access to it it over a year ago DRA worked great until the last couple months.
Now it rarely works at all. I know dish made a few changes to features etc on the DRA, that seems to be when the problems started to occur. I noticed several posts on this topic, so it seems to be a common issue.
I noticed that web activation is now an option on the 722, I had not done that before since it was not there, I tried to do that from that box and I got some kind of error.
I know my 722 has a good connection, I get a local id address etc, it runs through the same router all of my computers use.
Any ideas?
I checked I don't get any error codes just says cannot activate please try again later. I check the network setup and it says connection online. It has an IP address and everything...
The status should be "Connected Online" (yes, it is imperative that you not paraphrase nor translate error or status information).
Which way are you launching DRA?
connected
yes it says connected online. To use DRA I go to the dish network site and choose dish remote access. This worked great for a long time, until the recent changes.
Dishonline.com
Advice on Legacy 3 dish.
